Author Topic: Copy to Clipboard -> Full Structure for Duplication Error  (Read 8035 times)
GeistBW
« on: January 08, 2021, 05:14:49 am »
So I am used to using Copy to Clipboard -> Full Structure for Duplication . I used this a few days ago and it worked fine. I could even paste just fine. But now when I use this function, for a second it shows the progress bar like it is starting the copy, then this error comes up:
    Microsoft OLE DB Provider for ODBC Drivers [-2147217913]
    [Microsoft][ODBC SQL Server Driver][SQL Server] Conversion failed
    when converting the nvarchar value 'Approved' to data type int.
I haven't done anything with any "Approved" context.  I don't even know where "Approved" is used outside of the "Status" field in the Properties window.  Although everything I've done in Sparx, that field is left as the default value: Proposed.
Any idea on what happened?  Or how I can get back to how to make this copy function work again?
EA Sparx 15.0 and ProCloud Server 3
Thanx in advance.
