Author Topic: Attribute tagged values not visible in docked properties  (Read 7172 times)
« on: January 13, 2021, 08:18:11 pm »
Details:
When selecting an attribute in the project browser, the tagged values defined on the stereotype don't show in the docked properties window.
Only if the owner of the attribute is on the current diagram, the tagged values are shown.
In the properties dialog the tagged values are always visible.
Steps to Reproduce:
- create an attribute stereotype with some tagged values
- create a class with a stereotyped attribute and put them on the current diagram
- select the attribute in the project browser
- Notice that in the docked properties window the tagged values are visible
- Close the diagram
- select something else, and then the same attribute again in the project browser
- notice that the docked properties window doesn't show the tagged values. It looks like it's simply collapsed, but it is not possible to expand that section.
Reported
Re: Attribute tagged values not visible in docked properties
« Reply #1 on: January 13, 2021, 10:13:17 pm »
Hi Geert,
Sounds like another "things don't work properly unless the item is open in the browser" (like the Metatype/Type in Search).
« Reply #2 on: January 13, 2021, 10:34:47 pm »
Yes, I'm guessing the tagged values info only gets loaded if the attribute is visible on the current diagram.
« Reply #3 on: June 15, 2022, 10:03:20 pm »
Just check, but in v16.0.1605 the problem is still there.
Bit disappointing I must say. :(
