Author Topic: Populate Kanban using SQL  (Read 9296 times)
aaron.ve
« on: January 14, 2021, 03:26:12 am »
We're using EA 15.1, focusing on the Archimate stereotypes. We have a capability map, and we want to use it to associate capabilities with application components.
The ask is to have the business capability map show different colours, depending on the number of applications mapped against the capability. E.g., a capability with zero applications linked would be white, 1..2 would be green, more than 2 would be red (too many applications).
So,
- I can create a legend against a custom tag against the capability, which shows number of applications mapped, which can then colour code the capability. But we don't want to fill in the tag manually, as well as creating graphical associations... The only way of automating a tag I can see is:
- I'm looking at using a capability Kanban, and bind the Kanban to the defined custom tag in each capability. Bit of a workaround, but it's tolerable
What I'm looking for is some way in which I can populate the Kanban using SQL. The script would need to:
1. Pick up all capabilities in a package
2. For each capability, find number of connectors of type 'association'
Just checking before getting into this - a) has anyone done something similar, b) am I on the right track in your opinion, and most important (if I'm on the roughly right track), c) any guidance on the SQL I'd use, please?
Any help would be great. I've done a number of searches, and could not find the above addressed yet, but if I'm missing a thread, please feel free to point me there.
Thanks in advance!
Re: Populate Kanban using SQL
« Reply #1 on: January 14, 2021, 03:38:42 am »
I think you better look into writing a script for such a task.
You can use SQL to do the heavy lifting when it comes to selecting the elements you need, but for any change I would use the API rather then direct SQL updates.
I don't think you need the Kanban workaround. Scripts can create and fill in tagged values directly.
If you are looking for examples of scripts, look here: https://github.com/GeertBellekens/Enterprise-Architect-VBScript-Library
aaron.ve
« Reply #2 on: January 14, 2021, 04:25:59 am »
Thanks, Geert. I felt this was a long-winded way, and I guess you've confirmed it. And thanks for the link.
Just so I'm clear, though: you're suggesting a script would be best to pick the associations, AND populate the tag, right?
« Reply #3 on: January 14, 2021, 05:21:09 am »
Yes, but it might be faster to count the associations using an SQL query (Repository.SQLQuery) than it is to loop over them using the EA.Element.Connectors collection.
aaron.ve
« Reply #4 on: January 14, 2021, 07:53:56 pm »
OK.
Really appreciate the steer, thanks. I'll give it a try and let you know how it goes.  ;)
aaron.ve
« Reply #5 on: February 24, 2021, 03:58:34 am »
Sorry for the delay in getting back - life and other organisational stuff got in the way. I've attached the resulting JScript.
I think it's working the way it should.
The one area I struggled with is that I can't tell if a relationship is to an application component or not. In my metamodel I have a 'logical limiter' (i.e., you're not supposed to), but it would have been nice to identify this in the code.
Works on 15.1.
* Please be nice - it's my first scripting attempt.  :)
!INC Local Scripts.EAConstants-JScript
 * Script Name: Given a package, will iterate through Business Capabilities, and tag them
 * for realisation from Application Components
 * Author: Aaron A
 * Purpose: Prep a set of capabilities for heatmap
 * Date:
var tagName = "AssociatedApplications";
var cStereotype = "ArchiMate_Capability";
function main()
// Show the script output window
Repository.EnsureOutputVisible( "Script" );
debug( "In Script to Update Capability Tags " + tagName);
// Get the root package to work on
var contextObjectType = Repository.GetContextItemType();
if ( contextObjectType == otPackage )
// Get the context object as a package
var contextPackage = Repository.GetContextObject();
var rootElements = contextPackage.Elements;
var rootCount = rootElements.Count;
var iterator = 0;
while (rootCount > iterator)
var capabilityElement = rootElements.GetAt(iterator);
debug( "Root Capability: " + capabilityElement.Name);
updateTag(capabilityElement);
iterator = iterator + 1;
else
debug( "This script requires a package to be selected.\n" +
"Please select a package and try again.", promptOK );
debug( "END OF SCRIPT" );
/* For a given capability element, resets the tag, iterates through sub-cabilities
and assigns the return of tagConnections() to the tag. The assignment of the tag
value is cumulative based on the sub-elements
@param[in] capability (EA.Element) The primary capability that we will apply tag to, and
iterate from
function updateTag(capability /* : EA.Element */)
debug( "In Capability: " + capability.Name);
if (!(capability.Stereotype == cStereotype))
// not a candidate for this
return;
var elementTag = 0;
var subCapabilities = capability.Elements;
var subCount = subCapabilities.Count;
//has children?
if (subCount > 0)
var iterator = 0;
while (subCount > iterator)
var subCapability = subCapabilities.GetAt(iterator);
debug( "Sub-Capability: " + subCapability.Name);
// adds connections sum
elementTag = elementTag + updateTag(subCapability);
debug( "Cumulative tag: " + elementTag);
// adds connections to this capability
elementTag = elementTag + tagConnections(capability);
SetElementTaggedValue(capability, tagName, elementTag, true)
debug( "Final tag: " + elementTag);
return elementTag;
Goes through connections for the capability, and returns the number of connections to
an application component.
@param[in] capability (EA.Element) The primary capability that we will interrogate
function tagConnections( capability /* BusinessCapability as EA.Element */ )
var connections = capability.Connectors;
var connectorsToApplications = 0;
var connectionsCount = connections.Count;
//has connections?
if (connectionsCount > 0)
var iterator = 0;
while (connectionsCount > iterator)
var connector = connections.GetAt(iterator);
debug( "Connector Stereotype: " + connector.Stereotype);
// if the capability has been realised (logical limiter, to application components)
if (connector.Stereotype == "ArchiMate_Realization")
debug( "Found connector: " + capability.Name);
connectorsToApplications = connectorsToApplications + 1;
debug( "Total connectors for: " + capability.Name + " = " + connectorsToApplications);
return connectorsToApplications;
main();
 * Sets the specified TaggedValue on the provided element. If the provided element does not already
 * contain a TaggedValue with the specified name, a new TaggedValue is created with the requested
 * name and value. If a TaggedValue already exists with the specified name then action to take is
 * determined by the replaceExisting variable. If replaceExisting is set to true, the existing value
 * is replaced with the specified value, if not, a new TaggedValue is created with the new value.
 * @param[in] theElement (EA.Element) The element to set the TaggedValue value on
 * @param[in] taggedValueName (String) The name of the TaggedValue to set
 * @param[in] taggedValueValue (variant) The value of the TaggedValue to set
 * @param[in] replaceExisting (boolean) If a TaggedValue of the same name already exists, specifies
 * whether to replace it, or create a new TaggedValue.
function SetElementTaggedValue( theElement /* : EA.Element */, taggedValueName /* : String */, taggedValueValue /* : variant */, replaceExisting /* : boolean */ ) /* : void */
if ( theElement != null && taggedValueName.length > 0 )
var taggedValue as EA.TaggedValue;
taggedValue = null;
// If replace existing was specified then attempt to get a tagged value from the element
// with the provided name
if ( replaceExisting )
taggedValue = theElement.TaggedValues.GetByName( taggedValueName );
if ( taggedValue == null )
taggedValue = theElement.TaggedValues.AddNew( taggedValueName, taggedValueValue );
else
taggedValue.Value = taggedValueValue;
taggedValue.Update();
function debug( debugString /* String */)
Session.Output( debugString );
« Last Edit: February 24, 2021, 04:00:05 am by aaron.ve »
« Reply #6 on: February 24, 2021, 04:44:33 am »
If you want to know if a relation goes to an application component, you will first need to get the target element using the connector's supplierID as parameter for Repository.GetElementByID
Then you check the stereotype to make sure it's "Archimate_ApplicationComponent"
aaron.ve
« Reply #7 on: February 24, 2021, 09:43:32 pm »
Perfect!
That did it, thank you.
I used Repository.GetElementByID(connector.ClientID).Stereotype
Complete code, in case anyone needs it:
 * Author: Aaron A
 * Date:
function main()
var iterator = 0;
else
iterate from
return;
var elementTag = 0;
//has children?
if (subCount > 0)
var iterator = 0;
return elementTag;
//has connections?
var iterator = 0;
if (connector.Stereotype == "ArchiMate_Realization" && Repository.GetElementByID(connector.ClientID).Stereotype =="ArchiMate_ApplicationComponent")
debug("Found connector: " + capability.Name);
debug("Client: " + Repository.GetElementByID(connector.ClientID).Stereotype);
main();
taggedValue = null;
else
