Author Topic: Add "Relationship Matrix View" as a diagram default Mode of Diagrams  (Read 16861 times)
Martin_Bohring
It is possible to set the default diagram Views (Dialog Group Name is "Mode") within the diagram Property Dialog (Only in the Popup)
Currently (EA 15.2.1557) the following views can be selected:
"Always Open as Element List"
"Always Open as Gant*
"Allways Open as Specification"
The "Relation Matrix View" (only selectable via the Diagram header) is not among them.
My stakeholders like the "Relation Matrix View" much more than the Dependency Matrix (it is more graphical and presentable,
Unfortunately that view has to be selected again and again an cannot be made the default.
Sparx: Please consider adding the "Relationship Matrix View" as a Diagram Mode Option.
An while you are at it:
Please also make the column width and row height settings stick (make them persistent per diagram), so layout changes don't need to be made again and again as well.
Re: Add "Relationship Matrix View" as a diagram default Mode of Diagrams
« Reply #1 on: January 19, 2021, 07:17:34 am »
Martin
as this is a user forum what you will get here is feedback and support on your suggestions.
Please use the Feature Request link found under support at the bottom of Forum pages to raise this officially with Sparx.
If you have a relationship with an EA vendor or EA trainer ask them to request these feature from Sparx, as their requests may have some weight
Martin_Bohring
« Reply #2 on: January 20, 2021, 06:56:41 pm »
Done
