Author Topic: Diagram Layers Publishing  (Read 3622 times)
mgourde
« on: January 23, 2021, 07:56:21 am »
We have a problem with using the layers in a diagram. Visually it is doing the expected i.e. diffenrent objects placed on different layers with their respective relationships. When you hide some layers, only the relevant objects and relations are displayed.
Now if you save the diagram image or print it (printer or PDF) with only selected layers, the result shows the corresponding objects but all the relations or connectors from all the layers are saved/printed.
Anyone have experienced that case? Any solution?
mgourde
Re: Diagram Layers Publishing
« Reply #1 on: February 19, 2021, 04:50:01 am »
Update: A support ticket was opened. It is confirmed to be a bug with no target date for the fix.
