Author Topic: C code generation and typedef  (Read 32884 times)
Martin Merkel
« on: February 02, 2021, 01:19:28 am »
I'm trying to understand how to model typedef constructs in EA (15.2) such I get a typedef in generated C code.
Initially I started with C source and header files that look like that (simplified):
Class.c
#include "Class.h"
Enumeration_t Attribute;
and
Class.h
enum Enumeration
    Enumerator1,
    Enumerator2
typedef enum Enumeration Enumeration_t;
After importing the code into EA, I obtain the following:
When I then forward engineer C code, my typedef is gone. I cannot set any roles on the Generalization that EA thought to have identified between the <<typedef>> and the <<enumeration>>. I also cannot create a Generalization link between the typedef and the enumeration manually. What am I missing here?
Martin
« Last Edit: February 02, 2021, 06:37:52 am by Martin Merkel »
mse
Re: C code generation and typedef
« Reply #1 on: February 21, 2026, 12:21:33 am »
I modeled this one exactly how you have it shown and was able to forward-generate the C++ code. How did you create the generalization arrow from Enumeration_t to Enumeration1 however?
