Author Topic: Adding a hyperlink element to my custom toolbox  (Read 4341 times)
Knut Paulsen
« on: January 18, 2013, 11:08:16 pm »
Hi guys,
I want to add a hyperlink element to my toolbox, but I cannot find a suitable base metaclass.
If the above problem is solvable, then I would like to decide that this link is to another diagram, have the diagram selection dialog open automatically and add a default text to the notes field. Possible?
Cheers
Knut
Re: Adding a hyperlink element to my custom toolbo
« Reply #1 on: January 19, 2013, 12:21:33 am »
I'm currently not so deep in this matter. I would solve these (also your other thread) via a MDG add-in. Most likely there is no "native" solution.
You might wait a few days for others possibly having a solution.
Wivel
« Reply #2 on: January 19, 2013, 02:44:17 am »
Hi Knut
I am not quite sure what it is you are trying to achieve here and why. As far as I know, you cannot have hyperlinks in a Toolbox, so you need to rethink what it is you are trying to do.
Perhaps you can define a UML pattern and use elements from that instead?
Henrik
« Reply #3 on: January 21, 2013, 09:17:35 am »
"UML::Hyperlink"
Sounds like a job for an add-in. You will need to implement EA_OnPostNewElement where you will check if the element being created is a hyperlink or not, and then perform your processing. Except I don't think you can get the diagram selection dialog to open automatically.
