Author Topic: Diagram SelectedConnector only works from 2nd call  (Read 3361 times)
Guillaume
    • www.umlchannel.com
« on: February 11, 2021, 06:36:47 pm »
I have a script that selects a connector on the diagram. When this is executed, nothing happens. It's only when it's called a second time that it works ok.
On the following JSript sample, I noticed that duplicating "currentDiagram.SelectedConnector = connector ;" fixes the issue.
It seems to be a bug.
function OnDiagramScript()
var currentDiagram as EA.Diagram;
currentDiagram = Repository.GetCurrentDiagram();
if ( currentDiagram != null )
var connector as EA.Connector;
connector = Repository.GetConnectorByID(48039);
OnDiagramScript();
Guillaume
Re: Diagram SelectedConnector only works from 2nd call
« Reply #1 on: February 11, 2021, 06:52:15 pm »
Hi Guillaume,
I can confirm that there is definitely something weird going on when selecting connectors in a diagram.
I use that in the EA navigator as well, and I noticed similar inconsistent behavior (sometimes it doesn't seem to work)
I might try setting the selected connector twice, if that solve the problem.
Guillaume
« Reply #2 on: February 11, 2021, 10:11:00 pm »
Hi Geert,
Thanks for the info. I reported it as a bug, even though the workaround of calling it twice works for me.
Guillaume
