Author Topic: Hyperlink with connection string  (Read 3497 times)
PhilippW
« on: February 12, 2021, 12:15:38 am »
I am looking for a way to open a connection string to a EA database project from a diagram by use of e.g. a Hyperlink. I know there is the possibility to add an EAP shortcut as Artefact including the connection string but I'm looking for a solution which doesn't create a new Element in the Project Browser. Therefore I thought there is maybe a way to configure a hyperlink with a connection string or similar.
Thanks and regards,
Philipp
Re: Hyperlink with connection string
« Reply #1 on: February 12, 2021, 12:20:12 am »
Hyperlinks are interpreted by internet browsers. And they need a protocol connected with the link. So, unless you go to some authority and ask for such a protocol you will likely be out of luck.
