Author Topic: v15.2 – Can't use MDG-Based Tags to control Autocolour Legends  (Read 3757 times)
« on: February 12, 2021, 02:46:15 pm »
We tried to use Tags from our MDG in some Autocolor legends.  Whilst we could select them, they didn't work.
Anyone else seen this?
Because we'd been exposed to EAUI for so long, we created local (not MDG) Tags with the same name.  Suddenly the Autocolour Legend worked and correctly reacted to the MDG-based Tag values on the items!  NOTE: To confirm the EAUI; ALL the local Tag needs is the name.  The rest of the Tag can be empty.
Naturally, this is problematic for us since we don't want to create local tags (especially those that have the same name as our MDG based one!), confusion for our users is almost guaranteed.  We've decided that we want to allow only MDG based tags.
Reported,
Robert van Egmond
Re: v15.2 – Can't use MDG-Based Tags to control Autocolour Legends
« Reply #1 on: November 16, 2026, 11:08:18 pm »
Hi Paolo,
Did you find al solotion/work around for this problem? It seems like it still doesn't work in the latest version.
Robert
Sunshine
  • Its the results that count
« Reply #2 on: November 17, 2026, 01:48:54 pm »
Our ArchiMate Extension MDG has tagged values added that work fine with auto colour legends. You need to make sure you've ticked the active tick box in the legend properties and ensure your values match values for it to work properly.
We import the MDG into our model rather than reference it outside as separate MDG file.
Happy to help
« Reply #3 on: November 17, 2026, 06:55:58 pm »
I'm guessing the issue is with the "free range" tagged values that can be included in an MDG. These tag definitions are not tied to a stereotype.
You would see those tags as
[ProfileName]::Tagname
Whe've decided a long time ago to not use those types of tags, but only the ones defined on a stereotype
