Author Topic: Transitions and Triggers in hierarchical and parallel state machines  (Read 5256 times)
ngong
I refer to a transition as to be "an active source state is inactivated by the occurence of a trigger and a destination state becomes active."
Given a specific trigger, multiple transitions may happen. Usually they are documented on different state charts.
Question: How can I find all transition for a certain trigger, e.g. find all diagrams where the trigger is used?
I tried to name the transition connection after the trigger, but there is no diagram search for connections. Any other idea?
Rolf
PeterHeintz
Re: Transitions and Triggers in hierarchical and parallel state machines
« Reply #1 on: February 12, 2021, 10:45:30 pm »
I had the same problem.
What I do, is dragging the trigger into the state machine diagram and adding a trace relation between the transition and the trigger.
Best regards,
Peter Heintz
ngong
« Reply #2 on: February 13, 2021, 02:43:23 am »
Thank you PeterHeintz, that surely would work. However it may not be as reliable. It depends on manual accuracy.
I found this link and adopted the solution:
select c.Name as Name, ce.Name as ClientName,  ce.Object_Type as ClientType, se.Name as SupplierName, se.Object_Type as SupplierType, dg.Name as diagram
from (((( t_connector c
left join t_object ce on ce.Object_ID = c.End_Object_ID )
left join t_object se on se.Object_ID = c.Start_Object_ID )
left join t_diagramlinks dl on dl.ConnectorID = c.Connector_ID)
left join t_diagram dg on dg.Diagram_ID = dl.DiagramID)
where c.Name ='<Search Term>'
Now I can see the names of diagrams hosting the connection named after the trigger.
As I am not fluent in SQL queries, I'd like to know whether it is possible to have the search result in a way that I can click on the diagrams name to open it.
Rolf
« Reply #3 on: February 13, 2021, 05:27:57 am »
The trick to be able to select result is to return the two magic fields
- CLASSGUID
- CLASSTYPE
This search for example returns the diagrams based on an element name
select distinct d.ea_guid as CLASSGUID,d.Diagram_Type as CLASSTYPE,d.name as Name ,package.name as PackageName ,package_p1.name as PackageLevel1,package_p2.name as PackageLevel2 ,package_p3.name as PackageLevel3
from ((((((t_diagram d
inner join t_diagramobjects do on do.Diagram_ID = d.Diagram_ID)
inner join t_object o on o.Object_ID = do.Object_ID)
inner join t_package package on d.package_id = package.package_id)
left join t_package package_p1 on package_p1.package_id = package.parent_id)
left join t_package package_p2 on package_p2.package_id = package_p1.parent_id)
left join t_package package_p3 on package_p3.package_id = package_p2.parent_id)
where o.name like '#WC#<Search Term>#WC#'
or o.ea_guid like '<Search Term>'
« Reply #4 on: February 13, 2021, 09:34:32 am »
You missed another buck ;-) Maybe you could add a donation button? Though I think that only few people actually would really make a donation...
« Reply #5 on: February 13, 2021, 04:48:36 pm »
Yeah, and that is no problem. Donations are difficult in a corporate environment (you don't get an invoice for a donation, so how do you enter that into the bookkeeping?)
« Reply #6 on: February 13, 2021, 05:28:19 pm »
Maybe you could describe it as a "retainer"?
That way you wouldn't have to deliver anything, specifically.
