Author Topic: Generate Archimate Model Exchange file via scripting  (Read 4459 times)
bondgen
« on: February 15, 2021, 05:23:25 pm »
Dear support,
here https://sparxsystems.com/enterprise_architect_user_guide/14.0/model_domains/genarchmeff.html described how to generate Archimate Model Exchange file.
How to achieve the same via scripting, when I know package (GUID) where I want to perform such export?
This action available both from menu bar and as a menu item on right click on the package.
Re: Generate Archimate Model Exchange file via scripting
« Reply #1 on: February 15, 2021, 09:37:51 pm »
See the help ExportPackageXMI (string PackageGUID, enumXMIType XMIType, long DiagramXML, long DiagramImage, long FormatXML, long UseDTD, string FileName)
« Reply #2 on: February 16, 2021, 05:48:54 am »
I'm afraid Archimate Exchange format is different and not available through the API.
But hopefully I'm wrong.
« Reply #3 on: February 16, 2021, 06:11:44 am »
You're probably right. The XMIType does not list Achi. So, bondgen, write a feature request and be very patient. Alternatively, If you feel the urge, write your own exporter. That's possible but a lot of work. Blood, sweat and tears for free.
bondgen
« Reply #4 on: February 16, 2021, 09:13:08 pm »
Hi all,
Thank you for your answers.
Not good news.
I've tried ExportPackageXMI with all possible XMIType parameters and didn't achieve desired result. This function still exports XMI.
I trying to build up a tool chain based on Archimate language. Sparx EA could become a central part of it, as a modelling tool that helps to convert model to machine-readable format. And Archimate Exchange File format is what i need.
Be not able to automate this export makes usage of Sparx EA questionable. Especially when you forced to do already done job by yourself.
It's really sad, that MDG implemented as a patch without ability to use it via scripting.
Best regards,
  Gennadiy
