Author Topic: What is common between Partition and Alias at Actions?  (Read 4583 times)
ngong
« on: February 25, 2021, 05:31:56 pm »
Using EA 15.2. First, I was wondering why there is no Alias field shown in the docked Properties window of an Action, but a field named Partition at the same slot. Than I opened the Properties/Properties dialog, where I found the Alias field. Entered something in there.
The same value appeared at the Partition field in the still docked and open Properties window.
Is this just a bug in EA or is some meaning behind it?
Rolf
Re: What is common between Partition and Alias at Actions?
« Reply #1 on: February 26, 2021, 09:16:46 am »
Partition and Alias share the same db field. It's been that way longer than I've worked at Sparx Systems. There used to be an option for it, but I can't find it this morning.
ngong
« Reply #2 on: February 26, 2021, 04:02:01 pm »
Thanks Eve - so I can read Partition as to be Alias
(However in times where about every microcontroller has a memory managing unit, Partion should be an attribute to components, classes and every other element standing for executable code. Surely, its a static property. I cannot think of, what it means to attribute an action.)
Rolf
