Author Topic: Issue with upgrading DBMS (PostgreSQL) schema for Enterprise Architect repo  (Read 6347 times)
Vlada47
Hello, I am in the process of upgrading DBMS schema in a PostgreSQL database of EA repository from the version 851 to version 1558 with scripts from here - https://www.sparxsystems.com/resources/repositories/index.html. I downloaded the necessary scripts EASchema_Alter851to1220_PostgreSQL.sql and EASchema_Alter1220to1558_PostgreSQL.sql, however, when I ran the first script I got an error:
psql:EASchema_Alter851to1220_PostgreSQL.sql:627: ERROR:  relation "public.t_files" does not exist
psql:EASchema_Alter851to1220_PostgreSQL.sql:630: ERROR:  relation "public.t_files" does not exist
From what I can tell, it's from this section of the script:
CREATE INDEX ix_files_appliesto ON t_files (appliesto ASC)
CREATE INDEX ix_files_appliestoname ON t_files (appliesto ASC,name ASC)
CREATE INDEX ix_files_appliestonamesize ON public.t_files (appliesto ASC,name ASC,filesize ASC)
CREATE INDEX ix_files_appliestonamedatesize ON public.t_files (appliesto ASC,name ASC,filedate
ASC,filesize ASC)
CREATE INDEX ix_files_category ON t_files (category ASC)
CREATE INDEX ix_files_filesize ON t_files (filesize ASC)
CREATE INDEX ix_files_name ON t_files (name ASC)
Here I can see that two CREATE INDEX commands are referencing the "t_files" table with "public" schema, unlike the other commands. The problem is that I have all EA repository objects in a custom schema called "ea_repo" and I am running the script as user called "ea_repo", so all other commands end successfully.
My question is - can I safely assume these two CREATE INDEX commands are just errors in the script and I can solve the situation by removing the "public" schema reference for any further runs, or is there some specific reason the "public" schema reference is here and I should alter something in my database?
Thank you for any help.
All I  can say is that t_files does not seem to be used at all in EA. Probably some kind of legacy.
pvickers
If you use the model "Chat" features, you will find the notes are stored in the t_files table.
This is the case using Sparx EA version 15.2 at least...
Perry
Perry,
thanks for the update. Of course, when I wrote my Inside book, I did not chat to myself xD
