Author Topic: Enterprise Architect sequence diagram: cant select operation or properties  (Read 3812 times)
I am using EA Program Version: 15.1.1529 (Build 1529)
I have created a simple sequence diagram with two classes as vertical line on the diagram.
I create a message between the two classes without any issues.
I then right click on the message and want to select a public operation defined by the target class.
I am unable to right-click on message and find any UI to select any operation from the target class for the message.
When I try to right-click on message and select properties nothing shows.
What could be wrong?
« Last Edit: March 10, 2021, 03:53:54 am by [email protected] »
There are no classes to be used in an SD, only instances! EA lets you use classes, knowing that it's wrong and clobbering what you did once you ex-/import via XMI. Somewhere in the docs you find a warning. Unbelievable that this is still not fixed after so many years.
Properties show in  the 'Properties' docked window. In that window the top field should be a drop-down with the available operations from the target or you can click the button to select one using a dialog. (I don't have 15.1 running, this is from memory)
