Author Topic: search and replace  (Read 4074 times)
GrahamL
search and replace
« on: March 12, 2021, 09:07:35 pm »
Hi
I am looking for a search and replace feature
I want to replace all occurrences of string in all elements with another
Does such a feature exist?
Re: search and replace
« Reply #1 on: March 12, 2021, 09:21:42 pm »
To my knowledge: no. You would need to write a script.
« Reply #2 on: March 12, 2021, 09:49:35 pm »
I think someone once made some kind of tool to do that, but I don't remember who or where.
I'm pretty sure you should find some references to that in one of the forum posts.
Possible alternative solution: export to xmi, search/replace in notepad, import xmi
Be careful when doing search and replace. If your search string is not exact enough, you might end up replacing too much.
(e.g. you want to replace "car" with "automobile", but you end up changing "careful" to "automobileeful")
GrahamL
« Reply #3 on: March 12, 2021, 09:51:29 pm »
« Reply #4 on: March 15, 2021, 08:00:00 am »
If you're careful, you can export to XMI, edit the XMI in a text editor, and re-import.
Sunshine
  • Its the results that count
« Reply #5 on: March 15, 2021, 05:53:58 pm »
Just to add another option, if your repository is eapx you can open in MS Access and use that search and replace.
Happy to help
