Author Topic: Where is Ctrl-Shift-F gone in V15.2?  (Read 14325 times)
« on: March 16, 2021, 12:17:59 am »
WHIM? Where is my menu? Now also for keyboard shortcuts :-/
Re: Where is Ctrl-Shift-F gone in V15.2?
« Reply #1 on: March 16, 2021, 12:34:36 am »
Ctrl-Shift-F brings me to Search in Files.
Not sure if that has always been the case (I never used this shortcut)
« Reply #2 on: March 16, 2021, 01:03:42 am »
Formerly (13.5 and before) that opened the Find in browser window. Now it does what you said.
RoyC
  • Read The Help!
« Reply #3 on: March 16, 2021, 10:16:46 am »
That is not the option that you seek. The option that you seek is in the Project Toolbar (Start > Portals > Show Toolbar > Project Toolbar, then 5th icon from the left; a pair of binoculars over a Package icon).
The Help does say that Ctrl+Shift+F is a shortcut for this option, but that key combination - as you have discovered - is confined to opening the File Search dialog. I will correct the Help.
Best Regards, Roy
« Reply #4 on: April 09, 2021, 07:07:57 pm »
So it turns out that I have to dock that tiny toolbar below the ribbon to waste even more space on my monitor? Can't I just define the shortcut again? If so, where is that menu now? (This hide and seek isn't funny at all!)
BTW: Wasting space on the monitor: How can I get rid of that "Portals" menu to the right. It can't be collapsed or closed.
Sunshine
  • Its the results that count
« Reply #5 on: April 10, 2021, 12:00:41 pm »
Right click on the portal view at the top and select hide
Happy to help
« Reply #6 on: April 11, 2021, 07:14:45 am »
EAUI again :-/ The other windows have a fancy triangle to do the job. Ah, well. But thanks for the help :-)
« Reply #7 on: April 29, 2021, 12:08:31 am »
Argh! That toolbar got lost and somehow I can't find it again. It's probably some Perspective weirdness (but what are my perspecives other than searching in EA all day?). From 0 to 10 (for 10 being the best) design points I would give this UI a -1.
« Reply #8 on: April 29, 2021, 01:59:11 am »
You can enable/disable toolbars at Start | Desktop | Preferences | Toolbars
PS. Hmm, Paolo will probably object to my use of enable/disable; oh well  :P
« Reply #9 on: April 29, 2021, 04:21:17 am »
I supposed so. But that menu does no longer contain that entry. Sick of searching...
« Reply #10 on: April 29, 2021, 08:17:58 am »
The prosecution objects, Your honour!  ;)
The defence claims to be enabling/disabling the toolbar using that option, but in fact, the defendant is merely hiding/showing the toolbar!   ;D
I move that the members of the jury be asked to strike the original from the record and substitute the latter!
