Author Topic: extracting data from the repository with SQL - "is id" flag  (Read 5523 times)
Ru
« on: March 17, 2021, 09:55:01 pm »
Hi Folks.
I'm trying to pull data (specifically class definitions) from the EA repository. I've found most things, but I can't track down the location of the "is id" attribute flag. Anyone have an ideas? I cannot find any documentation on the repository data model (ironic really).
PS - does anyone know what SQL engine is built into the desktop app? It seems... finicky.
Re: extracting data from the repository with SQL - "is id" flag
« Reply #1 on: March 17, 2021, 10:39:14 pm »
The isId is in the t_xref in name=CustomProperties with type "attribute property". You need to look up the @PROP CSV data in the description column.
EAP = Mickeysoft Access
« Last Edit: March 17, 2021, 10:42:20 pm by qwerty »
philchudley
« Reply #2 on: March 17, 2021, 10:43:54 pm »
Hi
This is a trick one
If an attribute has isId set to true, then an entry  is made in the the table t_xref, which can be verified by
SELECT t_xref.Description
FROM t_xref, t_attribute
WHERE t_xref.Client = t_attribute.ea_guid
And the value in t_xref.Description is
Description,
@PROP=@NAME=isID@ENDNAME;@TYPE=Boolean@ENDTYPE;@VALU=1@ENDVALU;@PRMT=@ENDPRMT;@ENDPROP;
You can see that @NAME=isID@ENDNAME;@TYPE=Boolean@ENDTYPE;@VALU=1@ENDVALU; verifies that this attribute has the isID property set to true
Hope this helps
Phil
Models are great!
« Reply #3 on: March 17, 2021, 10:47:53 pm »
Here's an example query I use to list all classes and attributes (including isID)
SELECT c.ea_guid AS CLASSGUID, c.Object_Type AS CLASSTYPE,
 c.Name AS [Class name], NULL AS [Attribute name],
'Class' AS [Type], CASE WHEN c.Abstract = '0' THEN 'no' ELSE 'yes' END AS [Abstract], shared.Value AS [Shared],
NULL AS [M], NULL AS [ID], ts.Value AS [T], v.Value AS [V], dc.Value AS [DC], NULL AS [Datatype], 0 AS Pos,
p.Name AS [Package], p1.Name AS [Package +1]
FROM (((((((t_object c
LEFT JOIN t_objectproperties shared ON (shared.Object_ID = c.Object_ID AND shared.Property = 'Shared'))
LEFT JOIN t_objectproperties v ON (v.Object_ID = c.Object_ID AND v.Property = 'Versioned'))
LEFT JOIN t_objectproperties ts ON (ts.Object_ID = c.Object_ID AND ts.Property = 'Timesliced'))
LEFT JOIN t_objectproperties dc ON (dc.Object_ID = c.Object_ID AND dc.Property in ('Data Classification')))
LEFT JOIN t_object op ON op.Object_ID = c.ParentID)
INNER JOIN t_package p ON c.Package_ID = p.Package_ID)
LEFT JOIN t_package p1 ON p1.Package_ID = p.Parent_ID)
WHERE c.Object_Type = 'Class'
AND p.Package_ID IN (#Branch#)
UNION
SELECT a.ea_guid AS CLASSGUID, 'Attribute' AS CLASSTYPE,
 c.Name AS [Class name], a.Name AS [Attribute name],
'Attribute' AS [Type], CASE WHEN c.Abstract = '0' THEN 'no' ELSE 'yes' END AS [Abstract], shared.Value AS [Shared],
a.LowerBound + '..' + a.UpperBound AS [M], CASE WHEN x.[Description] IS NULL THEN 'no' ELSE 'yes' END AS [ID], ts.Value AS [T], v.VALUE AS [V], dc.Value AS [DC], a.Type AS [Datatype], a.pos AS Pos,
FROM ((((((((t_attribute a
INNER JOIN t_object c ON a.Object_ID = c.Object_ID)
LEFT JOIN t_attributetag v ON (v.ElementID = a.ID AND v.Property = 'Versioned'))
LEFT JOIN t_attributetag ts ON (ts.ElementID = a.ID AND ts.Property = 'Timesliced'))
LEFT JOIN t_attributetag dc ON (dc.ElementID = a.ID AND dc.Property in ('Data Classification')))
LEFT OUTER JOIN t_xref x ON (x.Client = a.ea_guid
AND x.Type = 'attribute property'
AND x.Description LIKE '%@PROP=@NAME=isID@ENDNAME;@TYPE=Boolean@ENDTYPE;@VALU=1@ENDVALU;%'))
ORDER BY [Class name], Pos, [Attribute name]
This query works for SQL Server, you might need to tweak it a bit for MS Access syntax.
Ru
« Reply #4 on: March 18, 2021, 01:27:53 am »
Thanks all - I would never have figured that out myself.
Now I just need to get around MS Access' syntactic peculiarities :/
« Reply #5 on: March 18, 2021, 01:35:22 am »
Or you could switch to SQL Server or any of the other supported DBMS (as long as you don't go for Oracle)
Ru
« Reply #6 on: March 18, 2021, 09:25:33 pm »
My colleague is working on it - unfortunately getting infrastructure sorted out in our company is slower than that Australian pitch drop experiment.
