Author Topic: ER Studio Migration  (Read 7370 times)
Tulkas
ER Studio Migration
« on: March 24, 2021, 10:25:57 am »
Has anyone out there migrated large ER Studio data models (logical and physical) in to Sparx?  If so any ideas on best way to migrate?  If not, suggestions welcome. Thanks much.
                              Art
Re: ER Studio Migration
« Reply #1 on: March 24, 2021, 04:24:39 pm »
I don't think there's a standard migration process for this tool.
So that leaves you with the classics. See if your tool can export to xmi, that you can import into EA.
If not you'll need to hire someone to write a custom migration tool. That's all doable, but you should count on a couple of weeks work; so quite a big investment.
Depending on the size of the model, it might be cheaper to migrate it manually.
Sunshine
  • Its the results that count
« Reply #2 on: March 24, 2021, 06:09:45 pm »
You can take a few approaches.
a) XMI export then import
b) Hire a professional developer to write a plugin
c) Hire an intern who is  a 2nd year software engineering student to write it.
Looks like a) as Geert suggested should be the first thing you should try as it looks like ER Studio can do that.
http://docwiki.embarcadero.com/ERStudioDA/185/en/Exporting_a_Data_Model_to_XML
If that doesn't work then you have b) or c).
Did a similar think but with PowerDesigner took option c) where I supervised as I could do it but just didn't have the time. Only do c) if you are a software engineer and could do it your self as an intern needs lots of guidance. Great experience to give an undergrad. Glad to say that intern went on to Graduate and got a great job afterwards due partially to the experience we'd given him.
Happy to help
Tulkas
« Reply #3 on: March 25, 2021, 01:51:40 am »
Couple of follow ons.
Other than XMI, is there a standard import export format for Sparx ERDs, .csv .xls?
Does Sparx support any VBA like capability where I could write code to import from a .csv or .xls?
« Reply #4 on: March 25, 2021, 07:59:57 pm »
There is no ERD default import, though CSV is supported. Scripting is (from my POV) the best solution. EA has build-in and external programming support.
« Reply #5 on: March 25, 2021, 08:10:22 pm »
CSV can only be used for elements (tables), not for attributes, relations, or operations.
Excel can be used. See https://bellekens.com/ea-excel-import-export/ or the standard Office MDG thing, but you'll have to build some additional stuff.
EA exposes an API that can be used by
- internal scripting
- Add-ins
- external programs using things like C# or Excel VBA
Guillaume
    • www.umlchannel.com
« Reply #6 on: March 26, 2021, 02:36:48 am »
I recently imported the XMI file generated by ER Studio to retrieve a data model.
Diagrams are not supported but I could generate the classes + attributes + associations.
I had to write a script to fix a few discrepancies:
- set the direction on all associations to unspecified
- replaced 1..1 multiplicities with 1
- when the Aggregation on the target is set to share and multiplicity is * or 0..*, the target Aggregation is updated with "none" and set to share on the source (it was the wrong way round)
Guillaume
Tulkas
« Reply #7 on: April 29, 2021, 08:05:03 am »
Many thanks folks!
