Author Topic: Reduce size of generated document/see file size of image assets?  (Read 4979 times)
Hurra
    • Find me at LinkedIn!
Hi!
I generate a document which gets quite big (in file size), compared to "normal" word-files. The generated document is not super big, under 30 pages. I use a lot of "Alternate Image" (ctrl+shift+w) in my diagrams to make them more pleasing for the stakeholder. My guess is that this might blow up the file size.
However, I checked one of the images. That specific image is only 139 kB, at least on my local drive.
Can I somehow see the size on images in the Image Manager? So I can change any images which might be to big?
Might it be something else that triggers the big file size?
Scale Saved Bitmaps?
Image Memory Limit?
Or is it nothing I can do besides reducing the number of diagrams? Which I'm afraid I can't.
Thank you!
always learning!
Re: Reduce size of generated document/see file size of image assets?
« Reply #1 on: March 29, 2021, 11:50:13 pm »
Have you tried to change something to the file (even if it's only adding a single space) and then save it in Word.
That usually helps to compress the file size quite a bit.
Hurra
« Reply #2 on: March 29, 2021, 11:56:32 pm »
I have not thought of that. Didn't know it was a thing  ;D
First I tried to generate as PDF.
Reduction in file size as PDF: 89%
Reduction in file size when adding a random space in Word and saving: 91%
Wow...
Thank you.
always learning!
