Author Topic: Role-TaggedValues not associated with roles  (Read 3091 times)
RIL
  • -- There's always a solution --
« on: February 05, 2013, 02:56:16 am »
I have a problem with TaggedValues associated with Roles. The TVs which I defined for my own extended stereotype role (bold.role) doesn't "attach" to the roles, only to the association. See screenshot far below.
I defined the stereotype (called <<bold.role>>) and added the TVs in the same manner as I did successfully with Classes, Attributes and Associations, (that is, Stereotype(bold.role)--extends-->MetaClass(Association) ), but for some reason the TVs doesn't show up as one set of TVs for each role.
I manually ensured that the roles has the correct stereotype, then I updated the model with "Sync Tagged Values and Constraints...", as usual, but the result is still as shown in the screenshot below.  If TVs can't be attached to individual Roles via the stereotype, then this is a show-stopper for me.
Q: What am I doing wrong?
// Rolf Lampa
Fig. The down-arrow indicates that the TaggedValues for roles should show up under respective role, not under the association:
« Last Edit: February 05, 2013, 04:07:06 am by Rolf_Lampa »
