Author Topic: Model Profile View  (Read 4170 times)
jdoran-anglo
Model Profile View
« on: February 06, 2013, 08:21:38 am »
Is it possible to mark packages with a tag that can then be programatically found to generate a HTML report?
We have a big model, and several projects that work in various sections of the model.
We want to generate daily HTML reports for each sub-model, and noticed that you can make packages non-reportable.
If not, would be generating baselines be a better solution?
Re: Model Profile View
« Reply #1 on: February 06, 2013, 06:48:27 pm »
There are all kinds of ways to do something like that.
I would probably use a tagged value.
OpenIT Solutions
« Reply #2 on: February 07, 2013, 04:44:00 am »
You need to look at Model Documents. You can create a Model Document to output to html. A model document can use a "Model Search" (again check out the help) to pull back specific packages to be included in your html. As Geert suggests you may want to add a tagged value to the document, which can then be queried in your model search - you may find that simply setting the package status and querying this will help.
Jon.
jdoran-anglo
« Reply #3 on: February 08, 2013, 02:28:17 pm »
Thanks. I will look into those suggestions.
EDIT: Just from looking at the help file, it doesn't seem like you can use tagged values or model searches.
The content of the report is defined as either:
· A list of packages (defined as attributes) dragged onto the element in whatever order or combination is most appropriate to your requirements; you can easily add or delete packages as necessary
or
· (Not for HTML reports) a standard model search (identified by Tagged Values) created within the Model Search facility; note that diagram searches are not supported - when you generate the document, this search captures the required data throughout the model and populates the document
« Last Edit: February 08, 2013, 02:36:31 pm by jdoran-anglo »
