Author Topic: Prolaborate - inconsistent report order in the dashboard  (Read 40532 times)
Guillaume
    • www.umlchannel.com
« on: May 04, 2021, 12:30:22 am »
Using the current 3.4.1.0 release, I created a dashboard with an EA Report widget. This report is using a SQL Query with results ordered by t_object.Name.
The preview on the dashboard doesn't show the classes in the correct order (the order is valid when the report is opened).
Guillaume
Prolaborate Support
  • Prolab Moderator
    • Visit us
Re: Prolaborate - inconsistent report order in the dashboard
« Reply #1 on: May 07, 2021, 07:00:00 pm »
Hi Guillaume,
Just to update,  the first column in the data table will come in ascending order by default since this default ordering in the script to order the reports generated using the designer.
Can you please try to apply t_object.Name as first column in query and check?
Guillaume
« Reply #2 on: May 07, 2021, 07:08:26 pm »
I can confirm that adding starting the query with "Select t_object.Name as hide_name, ..." fixed the issue.
Thank you for your help.
Guillaume
