Author Topic: Invalid combination of source and target types in matrix  (Read 23236 times)
« on: May 05, 2021, 09:10:43 pm »
Details:
When trying to add an ArchiMate3::ArchiMate_Flow relationship between two ArchiMate3::Archimate_ApplicationComponent in the relationship matrix we get an error saying:
Enterprise Architect
Invalid combination of source and target types for this connector type.
[ OK ]
This does not happen when trying to create the exact same relation in the diagram, or in the new relationship matrix diagram view.
Steps to Reproduce:
- Create 2 Archimate 3 Application components in a package
- make sure you have the option "strict connector syntax" on
- Open the package as source and target in the relationship matrix
- try create a flow connection between the two application components.
- Notice that you get an error and the relation is not created
- Notice that you can create the same relationship directly on the diagram without a problem
Reported
BCGoitcwoodard
Re: Invalid combination of source and target types in matrix
« Reply #1 on: May 25, 2021, 04:23:21 am »
(Sparx:) Where in the tool is this error coming from?  exactly what conditions trigger it?
I have received the same error in various circumstances, though I cannot remember the specifics.
CCW
DeBAAT
« Reply #2 on: August 27, 2021, 04:14:43 pm »
Hai,
Is there a solution for this issue yet?
I'm getting the same error.
Might there be another way to easily create a larger number of relationships, e.g. by using an import from excel?
Best,
Jan
« Reply #3 on: August 27, 2021, 05:28:19 pm »
Maybe Geert can post the issue tracker id and you can inquire the status from Sparx support thereafter.
« Reply #4 on: August 27, 2021, 09:06:14 pm »
The issue id is : 21057624
« Reply #5 on: August 30, 2021, 07:48:36 am »
There will be a fix in the next major release
Guillaume
    • www.umlchannel.com
« Reply #6 on: March 18, 2022, 08:59:16 pm »
I'm having the same issue with EA 15.2 build 1559. I tried EA16RC and I confirm that it's been fixed.
Has it been added to build 1560, or is there any plan to add to a new EA15.2 build?
Guillaume
wivel
  • Driven by Models
« Reply #7 on: March 18, 2022, 09:38:14 pm »
By 'next major release' do you mean when EA 16, EA 16.x or EA 17?
Henrik
« Reply #8 on: March 18, 2022, 10:25:43 pm »
That should be v16
