Author Topic: Output of python code generation..  (Read 6275 times)
KalpakD
« on: May 16, 2021, 09:25:52 pm »
Generated code from "basic python model" the Class A code is:
import ClassC
import ClassB
class ClassA:
    classC= ClassC()
    classB= ClassB()
    def OperationA(ParameterOne : int, ParameterTwo : int) -> int:
        pass
    def OperationB(ParameterOne : int, ParameterTwo : int) -> int:
        pass
The attributes have not generated any code.
Any other setting required?
Takeshi K
    • Sparx Systems Japan
Re: Output of python code generation..
« Reply #1 on: May 17, 2021, 10:26:58 am »
Hello KalpakD,
To generate Python attributes, you need to assign initial values.
Press Ctrl+5 to open the Feature window, then select the ClassA and enter some value to the Initial field. Then, generate source code again.
t-kouno
KalpakD
« Reply #2 on: May 17, 2021, 03:10:53 pm »
Dear Takeshi,
   That worked.
But is there a way to do model syntax check before generating code?
