Author Topic: Metaconstraint between different profiles  (Read 7723 times)
« on: May 18, 2021, 06:12:20 pm »
While I managed to create metaconstraints between elements of my own profile, I wonder how to do that between different profiles. Especially if I have own profile elements hookes up with standard UML elements. (Though I'm going on to mix several elixirs in the hope of the right pooof I appreaciate any hints here.)
Re: Metaconstraint between different profiles
« Reply #1 on: May 18, 2021, 06:38:13 pm »
Just add them as stereotype with their fully qualified name.
You can do that easily for build-in MDG's using the add metatype helper (but you are not a big fan of the helpers are you?)
« Reply #2 on: May 18, 2021, 06:50:22 pm »
I tried adding one that way, but it did not work. I'll poke around a bit more.
Yes, I don't like Clippy and its comrades. However, I will have a look. Probably I have to recover from current pains a bit more before doing so.
« Reply #3 on: May 18, 2021, 07:14:30 pm »
Ah, got it. It's possible to draw the constraint to the metaclass. So rather to UML::ActivityInitial I use the extending metaclass. Probably that would allow any profile extending it being the source. Well, I can sort of live with that. It's EA, still.
« Reply #4 on: May 20, 2021, 07:36:39 am »
...and set to abstract
« Reply #5 on: May 20, 2021, 08:42:48 am »
Hu, abstract. I never would have found that by myself. Thanks! I'll give that a try.
« Reply #6 on: May 26, 2021, 08:28:03 pm »
So i fought that windmill. It still swings its arms :-(
I added a FQN stereo to my profile and made it abstract. From this stereotype I drew a stereotyped relationship to one of my stereotypes. Once exported, the XML does not show any difference. Does Not Work.
« Reply #7 on: May 27, 2021, 07:47:59 am »
The abstract external stereotype needs to be the target of whatever constraint you are creating, not the source. You are adding constraints to your own stereotypes, not the external ones.
« Reply #8 on: May 27, 2021, 06:41:36 pm »
Hmm, I'm puzzled. I assumed the arrow to give the direction as to which a connector can be created and hence the _Meaning* attributes to be pulled out. With your advice that would prove to be incorrect. But then, how would I tell which way to read forward and backward??
P.S. I confirm that the above works. But now it only offers the connector the wrong way around. I want it to go from the external stereo to my own.
« Last Edit: May 27, 2021, 06:44:38 pm by qwerty »
« Reply #9 on: May 27, 2021, 07:15:28 pm »
We use stereotyped relationship for that.  We create a stereotype with the FQN of the external and then use the stereotyped relationship to it from the internal one.
« Last Edit: May 27, 2021, 09:39:34 pm by Paolo F Cantoni »
« Reply #10 on: May 27, 2021, 08:47:32 pm »
Seems pretty obvious :-[
Thanks!
