Author Topic: [EA 15.2] Copied & cleaned project size is the same  (Read 9475 times)
jack89
« on: May 19, 2021, 12:47:12 am »
Hi all,
here my scenario:
- project A -> size: 100 MB
- project B (copied from project A in which I deleted a lot of content inside it) the size is always 100 MB
Which is the main reason? In the project B there is much less content, but the size is the same of project A.
I deleted the elements from the project browser.
Thank you in advance
Re: [EA 15.2] Copied & cleaned project size is the same
« Reply #1 on: May 19, 2021, 12:54:15 am »
Jack, an .eap(x) file is essentially an access database.
The filesize is not directly related to the amount of data it keeps.
You can shrink the .eap(x) file using the option Configure | Model | Integrity | Manage .EAPX/.EAP file | Compact .EAPX/.EAP file...
« Reply #2 on: May 19, 2021, 03:39:29 am »
Not really. It IS related. Of course xD
It's just that Access does not do any garbage collection until you start some utility (via the menu you pointed out).
« Reply #3 on: May 19, 2021, 04:19:20 am »
That's wat "not directly related" means doesn't it?
Yes it is related, but not directly
« Reply #4 on: May 19, 2021, 07:51:08 am »
Well, in a mathematical sense it does not. But language permits emphasis which when written is lost. "NOT directly" and "not DIRECTLY" are lightly different. Of course I was just a bit joking and everyone knows what you actually meant.
q,
