Author Topic: Is it possible to reverse engineer Azure database with EA 13.10?  (Read 9791 times)
Richard Freggi
My database has MFA authentication and seems like the EA default SQL Server drivers don't support it.  Does anyone know if suitable driver can be obtained and how to install for EA reverse engineering?  Cheers!
Re: Is it possible to reverse engineer Azure database with EA 13.10?
« Reply #1 on: May 28, 2021, 03:25:09 am »
as long as you have an ODBC connection to your database it should work.
If you can't get it to work like that you might want to export your database structure to SQL create statements, and then recreate the structure locally.
That's what we do with databases we don't have direct access to.
Guillaume
    • www.umlchannel.com
« Reply #2 on: June 01, 2021, 07:23:52 pm »
Hi Richard,
Have you tried using the "Microsoft OLE DB Provider for SQL" driver ?
Guillaume
Richard Freggi
« Reply #3 on: June 01, 2021, 07:51:41 pm »
Thanks for advice Geert and Guillame, this database needs MFA authentication, which I don't think is available with the drivers I have access to.  But I'm doing OK using SQL Server Studio, so no issue.
Modesto Vega
« Reply #4 on: June 11, 2021, 01:26:24 am »
When you connect to the server using SMSS, are you using Azure Active Directory - Universal with MFA authentication? - please see https://docs.microsoft.com/en-us/azure/azure-sql/database/authentication-mfa-ssms-overview.
