Author Topic: removing connector after EA_OnPostNewConnector  (Read 5607 times)
Danny F
« on: February 21, 2013, 11:02:27 pm »
Hi
After (in) the EA_OnPostNewConnector the add-in can decide the connector should not be created.
How to proceed to remove the connector (apparently) already created ??
- this is a 'stateflow' connector on a FinalStateMachine diagram
- simply returning 'false' from EA_OnPostNewConnector doesn't suffice
As always : all and any help greatly appreciated.
Reg.
Danny
Re: removing connector after EA_OnPostNewConnector
« Reply #1 on: February 22, 2013, 12:08:52 am »
Danny,
If you want to prevent the creation of the connector then you have to use EA_OnPreNewConnector.
Otherwise, I guess you need to get one of the two ends, get its collection of connectors, loop that until you find the connector you need, and use Collection.DeleteAt() to delete it.
« Reply #2 on: February 22, 2013, 12:14:51 am »
However, it should be possible to control whether the properties dialog shall close after completion instead of just telling something has changed. I guess the "usual" use case is that you check some consistency and the user can choose to change or cancel. This applies to all On_Post events.
Danny F
« Reply #3 on: February 22, 2013, 12:30:43 am »
Thanks guys........but
I seem to run into 'special cases' all the time  ;)
@ Geert : that technique works, but not for a stateflow connector
it 'automagically' re-appears !
I have even deleted the entry myself in t_connector and it gets created again !! with a connectorID+1  :-?
@ Querty, a stateflow connector doesn't present a properties dialog
I wanted a challenge - seems like I got me one  ;D
Reg.
Danny
« Reply #4 on: February 22, 2013, 12:38:43 am »
Are you still using the OnPostNew connector?
I can imagine that, depending on the return value of this operation, EA will save the connector again.
If not it must be a bug.
Anyway, as a workaround you could save the details of the 'connector to delete' in your add-in, and then in the next event delete it (like OnContextItemChanged)
« Reply #5 on: February 22, 2013, 01:33:14 am »
Connector properties only pop up if Tools/Options/Links/Edit Connector on New is checked. So indeed connector treatment is even more complicated since the GUI behaves different to other elements.
Danny F
« Reply #6 on: February 22, 2013, 01:57:09 am »
Thanks Querty for this tip (and all help you tirelessly provide, same goes for Geert)
but it doesn't change anything
indeed, when Tools/Options/Links/Edit Connector on New is checked  the dialog pops up
Cancel on this dialog
or (hardcoded) returning false on the EA_OnPostNewConnector event
all to no avail - the connector (stateflow) stays where it is
Reg.
Danny
« Reply #7 on: February 22, 2013, 02:49:20 am »
That sucks, I know. There was a recent similar thread where someone suggested to trigger a timer and do the job a bit later. Geert also posted there.
