Author Topic: sql search to get the t_files entry for a class  (Read 8040 times)
GrahamL
« on: June 17, 2021, 07:18:17 pm »
Hi
I have limited sql experience but have a need to get the access to the t_files table for a give class
I would appreciate some help in getting started
thanks
Re: sql search to get the t_files entry for a class
« Reply #1 on: June 17, 2021, 09:11:29 pm »
What would you think to find in t_files? I never happend to find anything in there.
GrahamL
« Reply #2 on: June 17, 2021, 09:18:23 pm »
Hi
I want to get the code generation path
I have this
       private string getGenerationPath(EA.Repository Repository, string className)
            XmlDocument results = new XmlDocument();
            string sql = "SELECT File FROM t_files WHERE  name = " + className;
            string xml = Repository.SQLQuery("SELECT File FROM dbo.t_files WHERE  name = Class1");
            results.LoadXml(xml);
But when it is executed in my addin I get incorret syntax near the keyword 'File' File
« Reply #3 on: June 17, 2021, 09:39:48 pm »
Code generation path is found in EA.Element.GenFile
I don't think you'll find anything useful in t_files.
« Last Edit: June 17, 2021, 09:56:14 pm by Geert Bellekens »
GrahamL
« Reply #4 on: June 17, 2021, 09:41:21 pm »
Thanks Geert
« Reply #5 on: June 17, 2021, 09:42:42 pm »
Well, you asked the very same question and got an answer from me and Eve. Maybe you should get some sleep first?
GrahamL
« Reply #6 on: June 17, 2021, 09:46:57 pm »
Probably   :(
