Author Topic: profile defined connector created via add-in  (Read 4872 times)
Danny F
« on: February 26, 2013, 06:24:44 pm »
Hi
I have a problem applying a profile defined connector via the add-in
This is the profile snippet
<Stereotype name="BusinessEventTransition" metatype="BusinessEventTransition" notes="" cx="90" cy="70" bgcolor="-1" fontcolor="-1" bordercolor="-1" borderwidth="-1" hideicon="0">
      <AppliesTo>
             <Apply type="StateFlow">
                  <Property name="direction" value="Source -&gt; Destination"/>
                  <Property name="kind" value=""/>
            </Apply>
      </AppliesTo>
</Stereotype>
this is the add-in code :
EA.Connector newStateFlow = Initial.Connectors.AddNew("", "BIMProfile::BusinessEventTransition");
However the connector created hash metatype="Dependency" and type = "dependency"
what am I doing wrong ?
BTW I've got this technique working on an EA.Element of type 'State'
As always big thanks
Reg.
Danny
Paulus
Re: profile defined connector created via add-in
« Reply #1 on: February 26, 2013, 08:41:20 pm »
I don´t know the cause of this but some time ago i had a similar problem. Luckily i found a workaround so it didn´t bother me that much, maybe this will help you too:
Change the line into:
EA.Connector newStateFlow = Initial.Connectors.AddNew("", "StateFlow");
newStateFlow.Stereotype = "BusinessEventTransition";
newStateFlow.Update();
Be carefull  not to prefix ¨BIMProfile::¨ because that way EA seems unable to match your stereotype to your profile and this will result in a new UML type ¨BIMProfile::BusinessEventTransition¨ in your project (?!)
best regards,
Paulus
« Last Edit: February 26, 2013, 08:42:13 pm by pmaessen »
Danny F
« Reply #2 on: February 26, 2013, 08:52:13 pm »
Thanks Paulus, but that is exactly what I'm doing now  8-)
Problem is, my profile provider wants me to use the profile.
(So that later, if he adds to the profile it gets reflected automatically)
so my problem remains  :(
Reg.
Danny
Paulus
« Reply #3 on: February 26, 2013, 10:16:08 pm »
There´s one more Connector attribute you could use so i thought to give it a try, and, lo-and-behold: this attribute accepts the prefix!  :-? :D
So the following code will correctlty create the connector in BIMProfile (you can check this using the model search):
newStateFlow.[highlight]StereotypeEx[/highlight] = "BIMProfile::BusinessEventTransition";
nwStateFlow.SupplierID = ....
(... any additional changes ...)
Odd behaviour though...
« Last Edit: February 26, 2013, 11:48:51 pm by pmaessen »
« Reply #4 on: February 26, 2013, 11:34:37 pm »
In your example you missed setting theSupplierId.
Paulus
« Reply #5 on: February 26, 2013, 11:47:38 pm »
.... you're absolutely right => included this.
