Author Topic: Disable version control completely  (Read 15291 times)
Typia
« on: June 23, 2021, 10:43:41 pm »
Hi guys,
we configured a SVN version control which is now out of date and no more supported in our company.
I'd like to delete configurations in version control settings but it states that configuration is currently used in many packages and I can't find where disable it on those packages.
Is there any way to simply disable version control ?
Many thanks.
Re: Disable version control completely
« Reply #1 on: June 23, 2021, 11:14:54 pm »
You can manually remove version control from each package via the menu option Configure | Version Control | Package VC
You can do the same thing using a script
https://github.com/GeertBellekens/Enterprise-Architect-VBScript-Library/blob/master/Projects/Project%20A/Model%20Management/Remove%20From%20TFS.vbs
Or use the nuclear option and update the database directly
https://github.com/GeertBellekens/Enterprise-Architect-VBScript-Library/blob/master/Projects/Project%20A/Model%20Management/Remove%20All%20From%20Version%20Control.vbs
« Reply #2 on: June 23, 2021, 11:42:55 pm »
Would the nuclear version be fusion or fision? xD
« Reply #3 on: June 23, 2021, 11:44:49 pm »
Don't know. All I know is that it goes BOOOUM if something goes wrong  8)
Typia
« Reply #4 on: June 29, 2021, 07:55:34 pm »
thanks for your reply.
Problem is I have a lot of package which are configured, and I have to through each of them, often not knowing where they are in the Project Browser.
I took a look at your script and saw it was not allowed for SQL server repositories which is my case.
Can I make a request on db just to check which packaged are version controlled and disable it in EA then ? I think it's the safest way to do
« Reply #5 on: June 29, 2021, 07:59:07 pm »
That is simply a safety measure for use so we don't accidentally execute this on our production database.
You can disable that check by removing that part of the code.
Typia
« Reply #6 on: June 29, 2021, 09:38:58 pm »
Ok, but if I'm not mistaken in your script you only set iscontrolled field to 0, but version control also modifies a few other fields (XMLPath and maybe others).
If I run your script, it will set all packages to iscontrolled = 0 and may allow me to remove completely version control on project but will leave fields filled that should not be.
Am I wrong ?
« Reply #7 on: June 29, 2021, 09:49:17 pm »
Am I wrong ?
Yes, that might be correct. It's cleaner doing it through the "regular" script instead of the nuclear option, as that uses the API and should clean up those fields as well (although there is never a guarantee)
You could also modify the "regular" script to not start from the selected package, but instead work on a collection of packages returned by a query searching for controlled packages.
That combines the best of both worlds. The speed of using a query with the usage of the API to remove version control.
