Author Topic: Compare two models  (Read 10017 times)
Typia
Compare two models
« on: June 29, 2021, 07:50:47 pm »
I have two models stored in 2 different DB repositories, is there any way to compare differences between the 2 models ?
Many thanks,
Best regards
Re: Compare two models
« Reply #1 on: June 29, 2021, 08:19:27 pm »
The word "difference" probably needs elaboration.
Typia
« Reply #2 on: June 29, 2021, 09:34:50 pm »
Hi !
Elaboration :
Project B is copy of Project A 1 month ago
Team should have worked on project A but some team members worked on project B
I want to know which object are different between two projects
« Reply #3 on: June 29, 2021, 09:49:52 pm »
You can export (parts) to xmi and then compare to the xmi file.
« Reply #4 on: June 29, 2021, 10:14:35 pm »
You could also do a baseline compare within EA. In any case a model compare is not as easy as code or text comparison. So epecially if there's a chunk of work "somewhere". Better to have work done in a dedicated part and replace/import that. Even that has its pitfalls. Of course working permenently on a central model would be the best. But where you can't do that you need some integration team to bring work together and re-distribute the result.
Takeshi K
    • Sparx Systems Japan
« Reply #5 on: June 30, 2021, 10:01:24 am »
Hello Typia,
LemonTree could solve your problem. If I understand correctly, the latest LemonTree supports comparison between DBMS Repositories.
For detail, please ask to LieberLieber (developer of LemonTree).
t-kouno
