Author Topic: Diffenet code page in field Name and Notes? Problem with export of Notes  (Read 5951 times)
trenco
I have list of functional requirements in my model and diagram.
For each requirement is filled at least field Name and Notes. When I export list of requirements to CSV (via EA csv export/import tool) text in Name field is exported correctly, but the same text in Notes is in different code page, so intead of
REQ AM4: 019 íážýáýžáýťžáíé  I will get REQ AM4: 019 íážýáýžáýťžáíé
I have set in Manage project option - Source code engineering to code page (65001 UTF-8).
I have tried different code pages, result is the same.
What could be the problem and solution?
TIA
Tomas
Which EA version? Which database? If eap: have you turned on Jet4?
It's not a code page issue.
EA explicitly writes character references from some characters within the notes.
However, we do have a confirmed issue in our list that the CSV export should be converting these back to raw text.
