Author Topic: Import UI mockups in EA  (Read 16939 times)
K N
« on: February 23, 2013, 03:54:27 am »
Hi
Is it possible to import UI mockups in EA? or do i have to create in EA itself? or i can link the requiremnts to the documents which has these mockups?
The mockups are either in .png or .jpeg format?
KN
Re: Import UI mockups in EA
« Reply #1 on: February 23, 2013, 03:58:53 am »
Use the Common/Image context menu (when you press space while a diagram is selected). Then you can import the image and link it (via trace) to requirements.
K N
« Reply #2 on: February 23, 2013, 04:13:47 am »
where can i find the Common/Image context menu?
« Reply #3 on: February 23, 2013, 04:56:26 am »
Maybe your version is too old? With V10 its in the Common submenu in the lower 2nd third. Alternatively add a boundary and use Appearance/Select Alternate Image from its context menu.
K N
« Reply #4 on: February 23, 2013, 05:23:44 am »
I am using version 9.3.
Where do I find that? In EA main menus or in the Screen Element?
« Reply #5 on: February 23, 2013, 05:26:22 am »
It's the same in 9.3.
jfzouain
« Reply #6 on: February 23, 2013, 07:20:52 am »
Hi
Is simple:
1) Create an Extended - User Interface Diagram
2) Add a screen from the UI Toolbox (or a Bounday like Qwerty says)
3) Right click - Appearance - "Apply image from Clipboard" or "Select Alternate Image"
Done
Best regards
Jose Zouain
K N
« Reply #7 on: February 26, 2013, 06:49:07 am »
Thnks everyone for the reply....still have to try this out...currently troubleshooting the repository issue :)
K N
« Reply #8 on: February 26, 2013, 07:54:01 am »
Thanks everyone...it worked the way i was suggested to do :)
K N
« Reply #9 on: March 07, 2013, 07:03:32 am »
Hi
Importing UI mockups was working until today...today when i tried importing...it is saying "Unsupported file types" while the image files are .png or .bmp files which it was supporting previously..
What could be the reason for this??
KN
« Reply #10 on: March 07, 2013, 07:40:21 am »
Maybe they aren't what they pretend to be. Have you opened them with a viewer?
K N
« Reply #11 on: March 07, 2013, 07:50:11 am »
Yes...i did
K N
« Reply #12 on: March 07, 2013, 08:29:52 am »
its still giving me the error...i tried with other images too..thinking that ..that one particular image file could have been corrupted...
« Reply #13 on: March 07, 2013, 09:04:15 am »
reboot?
K N
« Reply #14 on: March 07, 2013, 09:09:31 am »
tried that too...but same thing
