Author Topic: VBScript retrieve ONLE value from SQLQuery  (Read 6529 times)
m2i7c9k
« on: August 07, 2021, 10:28:39 pm »
Hi Guy,
pleas HELP :) I'd like to retrieve from SQLQuery only ONE value <DestID>.
Sub Main
   Repository.EnsureOutputVisible "Script"
   Repository.ClearOutput "Script"
   dim currentDiagram as EA.Diagram
   set currentDiagram = Repository.GetCurrentDiagram()
   for each currentDiagram in currentDiagram.SelectedObjects
      dim theElement as EA.Element
      set theElement = Repository.GetElementByID( currentDiagram.ElementID )
      Dim sqlCmd
      sqlCmd = "SELECT " &  _
         "   Object_1.Object_ID AS DestID " &  _
         "FROM  " & _
         "   t_object  "  & _
         "   INNER JOIN t_connector INNER JOIN t_object AS Object_1 ON
t_connector.End_Object_ID = Object_1.Object_ID "  & _
         "   ON t_object.Object_ID = t_connector.Start_Object_ID "  & _
         "WHERE " &  _
         "    t_object.Object_ID = " & theElement.ElementID
      Dim queryResult
      queryResult = Repository.SQLQuery(sqlCmd)
      'LOGInfo (queryResult)
      getDiagramOccurences  (queryResult)
                The result id:
                2021-8-7 14:27:24 [INFO]: <?xml version="1.0"?>
               <EADATA version="1.0" exporter="Enterprise Architect">
          <Dataset_0><Data><Row><DestID>2</DestID></Row></Data></Dataset_0></EADATA>
                But I want to <DestID> value
End Sub
Thanx a lot
Mick
m2i7c9k
Re: VBScript retrieve ONLE value from SQLQuery
« Reply #1 on: August 08, 2021, 12:00:40 am »
So, I did it. Like this: good enough - for me :)
option explicit
!INC Local Scripts.EAConstants-VBScript
!INC EAScriptLib.VBScript-Logging
Sub Main
      Dim sqlCmd
      Dim queryResult
         "FROM  " & _
         "   t_object  "  & _
         "   INNER JOIN t_connector INNER JOIN t_object AS Object_1 ON t_connector.End_Object_ID = Object_1.Object_ID "  & _
         "WHERE " &  _
      queryResult = Repository.SQLQuery( sqlCmd )
      'Session.Output ( queryResult )
      Session.Output ( getDestObjectID ( queryResult )  )
   next
End Sub
Function getDestObjectID ( queryResult )
'   FUnkcia vráti ID asociované (<<use>>) objektu
      Dim str1,  str2, retVal
      str1 = InStr ( queryResult, "<DestID" )
      str2 = len(queryResult)
      retVal = MID( queryResult, str1, str2 )
      retVal = replace(retVal, "</Row></Data></Dataset_0></EADATA>", "")
      retVal = replace(retVal, "<DestID>", "")
      retVal = replace(retVal, "</DestID>", "")
      'Session.Output ( retVal )
      getDestObjectID = retVal
End Function
Main
« Reply #2 on: August 18, 2021, 02:19:57 am »
Wow, that is horrible code. :o
What you need is to parse the xml output using an xml library and then use those functions to retrieve the actual value.
Something like this:
'converts the query results from Repository.SQLQuery from xml format to a two dimensional array of strings
Public Function convertQueryResultToArray(xmlQueryResult)
    Dim arrayCreated
    Dim i
    i = 0
    Dim j
    j = 0
    Dim result()
    Dim xDoc
    Set xDoc = CreateObject( "MSXML2.DOMDocument" )
    'load the resultset in the xml document
    If xDoc.LoadXML(xmlQueryResult) Then
'select the rows
Dim rowList
Set rowList = xDoc.SelectNodes("//Row")
Dim rowNode
Dim fieldNode
arrayCreated = False
'loop rows and find fields
For Each rowNode In rowList
j = 0
If (rowNode.HasChildNodes) Then
'redim array (only once)
If Not arrayCreated Then
ReDim result(rowList.Length, rowNode.ChildNodes.Length)
arrayCreated = True
End If
For Each fieldNode In rowNode.ChildNodes
'write f
result(i, j) = fieldNode.Text
j = j + 1
Next
End If
i = i + 1
Next
'make sure the array has a dimension even is we don't have any results
if not arrayCreated then
ReDim result(0, 0)
end if
end if
    convertQueryResultToArray = result
End Function
m2i7c9k
« Reply #3 on: August 18, 2021, 02:49:28 am »
Thank you, Geert!
Well, it was horrible code, indeed :)
I rewrite it without SQL.
Your code will help me in other ideas, thank you again.
Mick
Sub main
   On Error Resume Next
   Err.Clear
   dim msg, appName
   appName = "A&D VBScript"
   if Err.Number <> 0 Then
      Session.Output( "NOK" )
      msg=MsgBox( "Unknown Error.", vbOKOnly  + vbExclamation , appName )
      Exit Sub
   else
      'Selected element type=Component check.
      if currentDiagram.SelectedObjects.Count = 0 then
         msg=MsgBox("Select 'Component' element.", vbOKOnly  + vbExclamation , appName)
         Exit Sub
      else
            set theElement = Repository.GetElementByID(currentDiagram.ElementID)
            if theElement.Stereotype <> "Component" then
               Exit Sub
            else
               'Check the element has connector.
               dim con as EA.Element
               set con = theElement.Connectors.GetAt(0)
               dim client as EA.Element
               set client = Repository.GetElementByID (con.SupplierID )
               if client.Name = "" then
                  msg=MsgBox("The connector is missing.", vbOKOnly  + vbExclamation , appName)
                  Exit Sub
               else
                  'Check connector type = Usage.
                  if con.Type <> "Usage" then
                     msg=MsgBox("The connector type must be a 'Usage.'", vbOKOnly  + vbExclamation , appName)
                     Exit Sub
                  else
                     set theElement = Repository.GetElementByID(client.ElementID)
                     dim theComponent as EA.Element
                     set theComponent = Repository.GetElementByID(currentDiagram.ElementID)
                     dim i
                     dim attributes as EA.Collection
                     set attributes = theElement.EmbeddedElements
                     for i = 0 to attributes.Count - 1
                        dim currentAttribute as EA.Element
                        set currentAttribute = attributes.GetAt( i )
                        'pondelok, 09 augusta 2021, 15:19:32
                        'check service name.
                        dim serviceName
                        serviceName = currentAttribute.name
                        if instr(1,serviceName,"(") <> 0 then
                           serviceName = mid(serviceName, 1, instr(1,serviceName,"(") - 1)
                        else
                           serviceName = serviceName
                        end if
                        'Session.Output("serviceName: " & serviceName)
                        'copy webpage interface to the component element
                        Call AddOperation (currentDiagram.ElementID, serviceName, currentAttribute.Notes)
                     next
                  end if
               end if
            end if
         next
      end if
   end if
End Sub
