Author Topic: Invalid Target for Sequence Flow  (Read 5423 times)
dstoicof
« on: August 11, 2021, 12:48:42 pm »
I'm on version 15.1.  While using BPMN 2 to create a workflow I get the error "Invalid Target for Sequence Flow" when I try to connect an outcome of a gateway to a message using the Sequence Flow connector.  It works fine for the other leg (EndEvent).   I can only connect the two using the Association connector.  Is there a guide that explains when to use Sequence Flow and when Association connectors?
Thank you!
Re: Invalid Target for Sequence Flow
« Reply #1 on: August 12, 2021, 08:28:23 am »
The specification is here: https://www.omg.org/bpmn/index.htm
There are probably tutorials scattered around the web.
