Author Topic: How do I hide stereotype in shapescript with "Show Stereotype Labels" setting  (Read 6097 times)
PeteC
I've added the stereotype of my custom connector in the middlebottomlabel but it is displayed regardless of the "Show Stereotype Labels" setting in the diagram properties for Connectors. How do I test for the "Show Stereotype Labels" setting so that I can suppress the label when unselected?
I asked that here but forgot the answer (since we finally resorted to something else). Will see if I can find it back.
P.S. Here it is: https://www.sparxsystems.com/forums/smf/index.php/topic,45272.msg266043.html#msg266043
« Last Edit: August 11, 2021, 08:47:30 pm by qwerty »
PeteC
I read through your previous post in detail and the (limited) amount of documentation - As far as I can make out StereotypeHidden only applies to elements and not connectors?
You can hide the stereo on connectors by adding a shape middletop/bottomlabel (not sure which it was, just try). Then decide upon the diagram setting as described. Just reading that in a haste :-/
