Author Topic: compositionKind not working on Aggregate metaclass  (Read 7439 times)
PeteC
« on: August 13, 2021, 12:48:47 am »
If I create my own connectors from an Association metaclass, the compositionKind correctly controls the Aggregation value (under the Target section in the Properties window) and whether the relationship has a black filled or un-filled diamond at the and.
If I change the metaclass to Aggregation, the compositionKind parameter has no effect. Is there something else that I also or instead of need to set for Aggregation relationship customisation?
Re: compositionKind not working on Aggregate metaclass
« Reply #1 on: August 13, 2021, 01:21:04 am »
Just thinking loud: there has been hassle with the aggregation. Not sure if you should use that metaclass at all. I think you should use an association with the aggregtion kind.
« Reply #2 on: August 13, 2021, 08:05:29 am »
Just thinking aloud: there has been a hassle with the aggregation. Not sure if you should use that metaclass at all. I think you should use an association with the aggregation kind.
Wot 'e sed! Pete,
Aggregation is NOW a deprecated Metaclass. It is retained for legacy reasons.
As Yul Brynner used to say... "Whatever you do, don' use Aggregation"   ;)
« Reply #3 on: August 13, 2021, 08:29:37 am »
You could change the metaclass to Composition
