Author Topic: v15.2 - What should [F2] do for vertices on diagrams?  (Read 8157 times)
« on: August 13, 2021, 04:00:09 pm »
We are/should be aware that the [F2] key will allow easy changing of the name which is visible on the rendered element on the diagram.
However, suppose we have [X] Use Alias if Available? and the rendered label is showing the Alias?  Would one normally expect the Name to be changed or the Alias?
Thoughts?
Re: v15.2 - What should [F2] do for vertices on diagrams?
« Reply #1 on: August 13, 2021, 08:12:12 pm »
I'd guess that the shown value will change. So the alias if opted. What does EA do? I guess they always change the name, do they?
« Reply #2 on: August 13, 2021, 10:33:29 pm »
You must be a Sparxian!  That is, indeed, what happens!
