Author Topic: How to show name as label for class created from image  (Read 9066 times)
ea1020
« on: August 15, 2021, 03:31:56 am »
I am sure there is a simple answer, but I don't see it.
I am working with an Azure diagram. I have imported all the Azure images.
In my diagram, I left-drag one of the Azure images onto the diagram and select "Add as element with image" from the popup menu.
The class is created, with the Azure image.
The problem is that the name I type into the Name field in the Properties does not show up, below the visual element, as a label.
The elements from the sample Azure diagrams do this, so I know it is possible. I don't see a "show label" or similar property that I can select however.
Thanks.
Re: How to show name as label for class created from image
« Reply #1 on: August 15, 2021, 06:31:58 am »
That might use a shape script displaying an image along with a label. IIRC an alternate image just shows the image and does not have a label.
Appears that I'm not really using alernate images and stick to UML standard notations....
« Last Edit: August 16, 2021, 03:29:53 pm by qwerty »
« Reply #2 on: August 16, 2021, 07:45:56 am »
right-click > Appearance > Show Name under Image
ea1020
« Reply #3 on: October 29, 2021, 02:54:31 pm »
Thank you
