Author Topic: SQL Query for two (or more) neighbours  (Read 7632 times)
Daiim
« on: August 23, 2021, 07:49:59 am »
I try to query two neighbors of a node but EA complains about invalid JOIN statement. Can anyone help?
SELECT objA.Name AS AName, objB.Name as BName, objC.Name CName
FROM (((t_connector relOne, t_connector relTwo
LEFT JOIN t_object objA ON (relOne.Start_Object_ID = objA.Object_ID AND relTwo.Start_Object_ID = objA.Object_ID))
LEFT JOIN t_object objB ON relOne.End_Object_ID = objB)
LEFT JOIN t_object objC ON relTwo.End_Object_ID = objC)
WHERE objA.Stereotype = 'ValueA' AND objB.Stereotype = 'ValueB' AND objC.Stereotype = 'ValueC'
Any ideas? Thank you for your help.
Re: SQL Query for two (or more) neighbours
« Reply #1 on: August 23, 2021, 08:19:20 am »
You haven't specified which database you're running on, which means I'm only guessing.
I think it's a bad idea (in at least one supported db) to mix a comma join with explicit joins.
Daiim
« Reply #2 on: August 23, 2021, 03:49:15 pm »
Do you refer to the first JOIN in context of t_connector relOne, t_connector relTwo?
So the query should be something like:
FROM ((((t_connector relOne, t_connector relTwo
LEFT JOIN t_object objA ON relOne.Start_Object_ID = objA.Object_ID)
LEFT JOIN t_object objD ON relTwo.Start_Object_ID = objD.Object_ID)
WHERE objA.ea_guid = objD.ea_guid AND objA.Stereotype = 'ValueA' AND objB.Stereotype = 'ValueB' AND objC.Stereotype = 'ValueC'
I've tried this one too, but also got complains about the JOIN syntax.
This query works, but object B and C are always the same, so the WHERE clause on stereotype does not work.
LEFT JOIN t_object objA ON rel.Start_Object_ID = objA.Object_ID)
LEFT JOIN t_object objD ON rel.Start_Object_ID = objD.Object_ID)
LEFT JOIN t_object objB ON rel.End_Object_ID = objB)
LEFT JOIN t_object objC ON rel.End_Object_ID = objC)
Database is an *.eap file repository.
« Reply #3 on: August 23, 2021, 04:33:59 pm »
You have to join t_connect relTwo the same way you are joining the other tables.
something similar to this (but you need to add a bunch parentheses for .eap)
from t_object g
left join t_connector cpg on cpg.End_Object_ID = g.Object_ID
and cpg.Stereotype = 'Archimate_Aggregation'
left join t_object pg on pg.Object_ID = cpg.Start_Object_ID
and pg.Stereotype = 'EAM_UserGroup'
left join t_connector cpg2 on cpg2.End_Object_ID = pg.Object_ID
and cpg2.stereotype = 'Archimate_Aggregation'
left join t_object pg2 on pg2.Object_ID = cpg2.Start_Object_ID
and pg2.Stereotype = 'EAM_UserGroup'
left join t_connector cpg3 on cpg3.End_Object_ID = pg2.Object_ID
and cpg3.stereotype = 'Archimate_Aggregation'
left join t_object pg3 on pg3.Object_ID = cpg3.Start_Object_ID
and pg3.Stereotype = 'EAM_UserGroup'
