Author Topic: v15.2 - Synchronize Stereotypes for Arcs  (Read 5497 times)
« on: August 24, 2021, 04:35:21 pm »
We have got synchronize Stereotypes "down pat" for vertices.  This allows us to extend the item properties as required.
However, we're finding some issues with the equivalent for arcs.   If we select the arc on the toolbox, sometimes it works and other times it doesn't.  We understand that in order for synchronizing stereotypes to work (even for vertices), the item needs to have the correct stereotype value in both t_object and the extended "Stereotypes" property in t_xref.  We thought that was all that was required (and certainly for vertices that seem to do the job).
Is anybody else successfully using synchronize stereotypes on arcs?
TIA,
Re: v15.2 - Synchronize Stereotypes for Arcs
« Reply #1 on: August 24, 2021, 06:11:34 pm »
I've never noticed any problems, but I can't say for sure I used this with stereotypes on relations.
« Reply #2 on: August 24, 2021, 10:30:37 pm »
Neither had I, but like you, I couldn't remember trying this on relationships.  So maybe the Sparxians can confirm all is (should be) well.
