Author Topic: LDAP Authentication Login in Pro Cloud Server  (Read 9644 times)
anggunutami
« on: August 26, 2021, 02:16:48 pm »
We have successfully installed Pro Cloud Server in our company but we still encounter an issue
We are having trouble with LDAP authentication:
If we connect to our company network using VPN (remote from out of office), we cannot access repository using LDAP login. It would take a long time trying to connect and eventually will display pop-up windows requesting user and password (user application)
Meantime, If we connect to our company network not using VPN (directly inside company network), we can access repository using LDAP login
Do you have any solution for this issue?
We need to resolve this issue since we implement policy which required all application should be able to be accessed using LDAP authentication.
OpenIT Solutions
Re: LDAP Authentication Login in Pro Cloud Server
« Reply #1 on: August 26, 2021, 05:54:05 pm »
I'd speak to your network admin, as this sounds like a firewall issue. They will probably need to whitelist the procloud server and ports you use for ProCloud connections on the server.
Jon.
