Author Topic: Inefficiency PCS Composite Diagram at WebEA  (Read 58011 times)
anggunutami
« on: August 26, 2021, 02:45:42 pm »
We have succesfully installed Pro Cloud Server in our company but we still encounter an issue
We have already sync and transfer the file project into the Sparx Desktop Application
If we started at WebEA and open the composite diagram, is there any reason for why we cannot directly open the composite diagram? we have to repeatedly click on the browser tab.
Kindly need your suggestions, thank you
Re: Inefficiency PCS Composite Diagram at WebEA
« Reply #1 on: August 26, 2021, 03:22:36 pm »
I'm not sure I'm understanding what exactly the problem is.
anggunutami
« Reply #2 on: August 26, 2021, 04:38:44 pm »
I cannot directly open the composite diagram by click on the diagram (graphical view), I have to find on browser to choose the composite diagram
« Reply #3 on: August 27, 2021, 06:12:12 am »
Are you using WebEA?
What DB are you using for the model?
Does your EA client use the same database and model?
OpenIT Solutions
« Reply #4 on: September 14, 2021, 05:36:50 pm »
This is a configuration in WebEA. You can either click to open composirte diagram, show mini property sheet and then click on its composite diagram link or open main property sheet. See https://sparxsystems.com/enterprise_architect_user_guide/15.2/pro_cloud_server/configure_webea_via_web.html and then https://sparxsystems.com/enterprise_architect_user_guide/15.2/pro_cloud_server/edit_webea_model_connection_settings.html
Jon.
