Author Topic: Export a list of EA objects into a JIRA or Polarion custom field  (Read 9295 times)
BiSb
we are currently trying to integrate EA into our process and development tooling. Currently we are using JIRA also as requirements management system (I know, not quite the best to do), but we are evaluating also Polarion.
One of our use cases is to map requirements to specific class or component from EA. My question now is, is it possible to export a list of a specific EA object type to JIRA or Polarion into a custom field (type)? Maybe with a external Tool/Add-In like the EAConnector or does Prolaborate/Pro Cloud provide such a feature?
Greetings
Sebastian
Re: Export a list of EA objects into a JIRA or Polarion custom field
« Reply #1 on: August 31, 2021, 07:44:59 pm »
I once had to synch EA with DOORS and found it the best solution to script it on your own since that gave the most flexible solution. We had requirement elements defined in out profile with an ID as stereotype property that used to hold the DOORS ID for later synchronization.
« Reply #2 on: August 31, 2021, 09:45:12 pm »
Yes, Using Prolaborate its possible to link the existing EA items with existing Jira Items. Once the link was added , EA Element will have that Jira item link in its tagged value and the Jira Item will have the Prolaborate link of EA Item in the Web links as below
A
Sunshine
  • Its the results that count
« Reply #3 on: September 08, 2021, 02:08:35 pm »
I understand from a webinar that integration with Polarion is coming Enterprise Architect V16. Beta of V16 coming next week
Happy to help
