Author Topic: How to edit fields in the Enumeration block?  (Read 12523 times)
DominikS
« on: September 08, 2021, 09:02:33 pm »
I have no clue how to edit tags defining the set of elements in the Enumeration block. Do you know the way? If the only option is to delete the tag and create the new one it seems to be a bug.
I am using SysML 1.5, EA 15.2.
DS
Re: How to edit fields in the Enumeration block?
« Reply #1 on: September 08, 2021, 09:23:57 pm »
I don't know SysML in that detail, but enumerations are (in UML) just certain classes whose attributes are the enumeration elements. Roughly spoken.
PeterHeintz
« Reply #2 on: September 09, 2021, 04:46:28 pm »
This is the same thing in SysML.
Best regards,
Peter Heintz
DominikS
« Reply #3 on: October 12, 2021, 02:03:25 am »
Thanks. I now the idea but its handling is wired.
« Reply #4 on: October 12, 2021, 09:14:05 am »
Anyhow you should accept Geert's answer on SO as correct...
