Author Topic: How can I retrieve the value of a MEMO Tag in a Shape Script  (Read 5252 times)
Pierre Beyssac
« on: September 23, 2021, 10:34:45 pm »
Hello everybody,
Do you know how can I retrieve the value of a MEMO Tag in a Shape Script?
If this is not possible, is there another solution to allow the entry of a list of IPs for example from a simple Tag (Tag carried by an element of an MDG)?
Thanks in Advance
- Pierre  ;)
Re: How can I retrieve the value of a MEMO Tag in a Shape Script
« Reply #1 on: September 23, 2021, 10:57:43 pm »
I don't think you can.
And a regular tag can hold only 255 characters, so you will only be able to fit a limited number of IP addresses there.
Possible alternative is to provide as many tags as you will ever need.
e.g.
- IP1
- IP2
- IP4
You can address each of those individually in your shape script and print them.
Pierre Beyssac
« Reply #2 on: September 24, 2021, 03:30:22 am »
Hello Geert
Thanks a lot for your reply.
I will go back to the alternative solution
