Author Topic: Showing the COUNT-Ratio of seperate Select statements in a PieChart  (Read 6678 times)
wzr
lets say I'm having two (or more) seperate SELECT statements. Each of them return a number of Elements from t_object.
What I would like to show in a PieChart is the ratio of the COUNT result of the SELECT statements to each other.
I.e. a simple query like this:
SELECT t_object.Name FROM t_object WHERE t_object.Name LIKE 'Example_#WC#'
giving 10 rows as result
and another one:
SELECT t_object.Name FROM t_object WHERE t_object.Name LIKE 'Example2_#WC#'
giving 5 rows as result
I would like to create a PieChart showing a 10/5 ratio.
Sounds easy but I can't get it done   :-\
Thanks a lot!
wzr
Re: Showing the COUNT-Ratio of seperate Select statements in a PieChart
« Reply #1 on: September 28, 2021, 09:19:12 pm »
No suggestions?
Is the question unclear? Or is there no easy solution?
Thank you!
« Reply #2 on: September 28, 2021, 10:19:13 pm »
You can always combine separate select queries as subqueries or with unions into a larger query.
e.g.
SELECT o.Name, 'Example' as Category
FROM t_object o WHERE
o.Name LIKE 'Example_#WC#'
union
SELECT o.Name, 'Example2' as Category
o.Name LIKE 'Example2_#WC#'
Does that help?
« Reply #3 on: September 29, 2021, 10:12:11 am »
Assuming you're talking about the EA chart objects...
https://sparxsystems.com/enterprise_architect_user_guide/16.0/model_publishing/chart_query.html
You need to return a column 'Series', which gives you
SELECT 'Example' as Series
union
SELECT 'Example2' as Series
wzr
« Reply #4 on: September 30, 2021, 04:25:16 am »
Thanks for your help.
I got what I was looking for with an attempt like this:
SELECT o.Name, 'Example' as Series
union
SELECT o.Name, 'Example2' as Series
If the 'Series' column is the only one selected, its always a 50/50 ratio, cause the result is only one row for each Select query.
The 'Category' column Geert proposed is propably for another Chart Element? My StandartChart (EA 15.1) doesnt process that one.
« Reply #5 on: September 30, 2021, 08:17:31 am »
Sorry, that's the other change I was going to make. You need 'union all'.
