Author Topic: Problems with Templates and Scripts  (Read 9470 times)
emiliano.davila
« on: September 29, 2021, 05:26:22 am »
Hi, we are working with templates and scripts for report generation, but we are getting a problem when trying to get the linked document of an element.
The script is as follows:
And the template is as follows:
The fragment "Template - DER Short DocVinc" refers to the script mentioned above. When generating the report we get the following error:
Any idea how to fix it?
philchudley
Re: Problems with Templates and Scripts
« Reply #1 on: September 29, 2021, 07:00:57 am »
A script driven fragment has to return an XML document, and a linked document is not in XML format.
Not sure why you are using a script, since the element section, once expanded has a linked document section, which when selected will insert the contents of the linked document.
Remove the template fragments.
Expand the element section (the checkboxes)
Select Linked Document (If I remember correctly there are no fields to insert, just the linked document section
Save the template and regenerate.
Phil
Models are great!
emiliano.davila
« Reply #2 on: September 29, 2021, 10:25:23 pm »
We are using a script because to generate the report we use the elements of a diagram, and these elements do not have more properties to add.
We made a script to return the files of the diagram elements, but with the linked documents we have not been able to do it. As I understand, the xml that the template receives has a specific format. Is there any way to transform the linked document into an xml with that format?
« Reply #3 on: September 30, 2021, 03:38:03 am »
No, it doesn't work that way.
But you can use a Document script template and return the RTF code as is.
See https://sparxsystems.com/enterprise_architect_user_guide/15.2/model_publishing/document_script_fragment.html
Or else use a virtual document to reference each of the used elements individually.
emiliano.davila
« Reply #4 on: September 30, 2021, 10:53:25 pm »
Thank you both very much!
